Need a little help with spark plugs
EZSteury
For My 1984 evinrude 35hp. I went to westMarine and they sold Me NGK BR7HS 10 but I removed a set of spark plugs from the previous owner with a different part #. Are the ones i got the best spark plugs for this OB.
JDusza
Ensign
Re: Need a little help with spark plugs
IMHO, nope. I'd look for Champions.
J
EZSteury
Can You tell Me which ones, I think the old ones that came with the motor are champions I will check later. Thanks.
F_R
Actually, the correct Champion number is L77JC4 or QL77JC4. That does not mean NKG does not have an equivalent. But I don't know what the correct crossover number would be. That is what you need to find out in order to answer your question.
EDIT: Ok, so I looked it up. QL77JC4 converts to BZ7HS-10, and L77JC4 converts to B7HS-10. Your number is slightly different and I don't know how much of a difference it makes. See, that's the trouble when you start making conversions.
EZSteury
Thank You, I can just order champions I'm not loyal to the NGK's, heck I don't really know which is better. I will order the ones You posted.
Vic.S
The NGK BR7HS-10 is a resistor plug. The are often quoted as equivalents to the recommended Champion QL77JC4 plugs but they are not suitable for the OMC ignition system, and they will cause poor running
The Champion Q series are inductively supressed, not resistor supressed. BZ7HS-10 are inductively supressed and should be suitable.
L77JC4 are not supressed. The NGK equivalent is B7HS-10
Incidentally the heat rate numbers for NGK plugs runs the opposite way to Champions. Higher number is cooler.
The -10 part of the NGK code indicates that they are supplied gapped to 1.0mm (0.040"). The gap now recommended for the engine in question is 0.030".
EZSteury
Tomorrow I'l go by the part store and buy a new set of spark plugs which should I get L77JC4 or QL77JC4?
Thanks.
Vic.S
Thanks.
QL77JC4 are the ones listed.
L77JC4 are not suppressed and will cost less
F_R
"Suppressed" means they don't make static noise on AM radios and some electronics.
EZSteury
Then QL77JC4 champions it is. Thank You all very much.
