I picked this boat up a few weeks ago, took it out for the first time Last Sunday the 17th, as a trail and error to see how everything did, i found out that most the gauges didn't work and the motor had alot of Blow By at Full throttle also wouldn't idle with water running in it, it come down to the exhaust manifolds were shot i try fixing them with very little luck, i spent the bucks and got new Manifolds it idle fine now in the water, the motor only has 1 Vacuum Port and it runs a device in the back of the boat that i believe forces it in Neutral (I could be Wrong) after what happen this weekend, at low speed it would not going into Neutral at all, at High speed it would go into Neutral every time, I placed a T in that line to run a PCV valve to cut down the blow by it helped but didn't stop it at Full throttle it will still puke Oil out the filler Cap I don't know if the Motor is under alot of Stress or What, an idea was to install a 1 inch Spacer under the carb for another Vacuum Port, i would have no problem doing that but i can't find or make the choke work right i posted what the boat did Sunday 3000Rpm at 38 MPH i have been told thats not right, if i did get it up to 4000 to 4200 Rpm will that cut down on Blow by? I have been told the Props for the II drive are hard to find and they are i can't find any Prop under 19 pitch.<br />I know these v-8 chevy motors back in the 60's had alot of blow by i would like to fix this with pcv valves.<br />Does anyone make a Small Electric Vacuum pump that can run that device? Any other way to get another Vacuum Port? Any Ideas at all?<br />Thanks
