need a good range rover forum
bandit86
Banned
I went to about 20 forums already, but not much help with my stiff steering on my 92 range rover. rangerover.net and difflock.com seem to have the most traffic, but even they are dead compared to Iboats. heck, I have been giving most of the tech support.
bomar76
Re: need a good range rover forum
My son has a 1997 Discovery 1 SE7<br />landroversonly.com/forums<br />landroverforums.com<br />landroverworld.org/forums<br /><br />for a few...<br /><br />atlanticbritish.com is a great parts source.<br /><br />Define the "stiff steering" a little more....
bandit86
Banned
just seems too hard to turn, the problem is narrowed to the steering box (steering output arm removed) it's nice and free for the middle 4 inches, then gets hard to turn, and the steering wheel doesnt self center either. we adjusted the middle 7 inch deadspot out of it but steering is still stiff, we turned the adjustor on the side out a turn and a half. it's definately better when the engine is on so I know we have partial assist anyways
bomar76
How many miles on it?<br />Rover steering boxes are notorius for wearing out...
bandit86
Banned
112000miles. it's not leaking though, which is what they are famous for
bomar76
How to correctly adjust the power steering box on a Range Rover:<br /><br /> With the wheels in the <br />straight ahead position, turn the steering wheel and measure how far <br />it turns before resistance is felt - any more than 1in calls for <br />adjustment. <br /><br /><br />Raise both front wheels off the ground and <br />support the Land Rover on axle stands, taking safety precautions.... <br />The vehicle front wheel must be off the ground so that you can turn <br />the steering over the full extent of its travel.<br /><br /> Use a 19mm spanner to release the locknut then <br />adjust, using a 6mm Allen key. turn the steering wheel from lock to <br />lock, and then back to the centre. If you can feel any 'tight' spots, <br />the steering is too tight and the Allen key should be backed off until <br />no stiffness can be felt, turning the steering several times over the <br />full extent its travel.<br />Once the correct amount of adjustment has <br />been attained, hold the Allen key in position while you tighten the <br />locknut. This requires some care, as it's easy to turn the Allen key <br />at the same time.
bomar76
At 112K I strongly suspect it is worn out and the attempts to tighten it are just creating another problem.
bomar76
Also.....do you have equal turns from center left and right?
bandit86
Banned
roughly the same, i have not measured it, not obviously different. thanks, those were the instructions I used to adjust it. There is also an adjustment on the side of the box, I read in an online manual is used to tighten up the feel of the steering, I loosened it right off and tightened it just a 1/4 after touching
bomar76
The above instructions are for the screw on the side of the box....and that's EXACTLY how you have to do it, not 1/4 turn after touching. <br />What else did you do/adjust?<br /><br />It's very important the turns left/right from center are equal in all Rover boxes.<br /><br />You need to check that and post results.
bandit86
Banned
the 19mm locknut and 6mm allen key are on top of the box, right beside the bleeder screw. there is a second adjutment on the side that has a 3.5mm allenkey setscrew holing a large diameter sloted bolt about 1inch in diameter
bomar76
Centr of the box is equal distance between <br />locks. <br />Remove the drop arm and turn the <br />steering gently until the steering box hitsits internal lock stop. From this <br />position you turn the opposite direction exactly 2 full turns. Turn initially towards the centr of the vehicle. <br /><br /><br />If you set the box on the mid way lock to lock position and adjust out the <br />free play, you will introduce a tight spot and trouble is looming further <br />down the line.
bandit86
Banned
this vehicle was owned by a monkey. when my brother brought her home, #5&6 wires were on backwards, actually marked wrong on the cap by marker, which I think made him sell it, the engine ran like crap. (I bought it unseen) The steering had huge deadplay on it. I found the arm on the output shaft was 1 full turn loose, hence most of the play. I think the previous owner tightened the adjustment screw to compensate but to no avail. I adjusted it acording to the online manual I found, little better, but still no good. Car is almost driveable now, felt like no power assist before at all.
bomar76
For $295 I'd put a new / rebuilt box on it and be done with it....<br />carsteering.com/addtocart~year~1992~make~Land%20Rover~model~RAN~modelname~Range%20Rover~part~82-00108~cnsuffix%3DAll%20Models.asp#<br /><br />as I sid they are notorius for wearing out, leaker or not.
bandit86
Banned
I want to be sure the pump is still working properly befor I fix something else, but I do thank you for your help. <br /><br />p.s. I that your picture?
bomar76
Yeah, my High School Senior Class picture....I wished I looked that good now!<br /><br />As for the pump, I seriously doubt that is the problem, it's the box and it's either worn out or the prior owner fubared it by blind shadetree adjustments trying to correct for normal wear.
JB
Non-boating tech topic.
bandit86
Banned
went to a steering rebuild place, the guy showed me a 3rd adjustment, said thats to be adjusted first, its a 1 1/4 inch plug on the front of it held down by a thin locknut. then the one on the side, finally the one on the top. will try it later.
