Need a drain plug for a 1988 Force 125HP
dewayne4
I am in search of the hex (allen) head drain plug for the lower unit on a 1988 Force 125. It is NOT the Slotted Fill nor the Vent Plug, but the plug at the very very bottom of the motor. I have checked several local marine stores and numerous online web sites. Any suggestions?
Jiggz
Re: Need a drain plug for a 1988 Force 125HP
It's a regular hexagonal head so I'll check Ace Hardware and I'm quite sure you can find it.
jerryjerry05
pnwboat has the right thing!!!I buy from there a lot.J
jason32038
I accidently ran into one while looking for something else in the nuts and bolts section at Lowes.
patrickj
i believe the head plug is the same, if you dont have a pee hole you could usethat one if you you need a temp fix, just add a pee hole.
jerryjerry05
You advertising for another site.That might be why it won't show.
The plug on top of the head won't work.Wrong size.J
jason32038
Head plug is way bigger than the drain plug on the LU.
jerryjerry05
You should start your own thread.
"Thread Starter"
Adding on an old post only gets the mods upset.
The low comp is probably the gauge and not a real reading.
You pull all the plugs?
Timing?? What/ how did you set it at?
99.9% of the time, timing doesn't need adjusting.
The way the motors set up it doesn't change unless YOU do something to it.
The "idle" screws aren't idle screws they're air/fuel mixture adjustment screws for running at idle.
Missing at idle:Turn them(air screws) in till they just bottom out(gently) then out 1 and 1/2 turns till you can reset in the water.
Then while warm and in gear you adjust.
One of the top post is a linc and sinc. Do this and try to do the static timing.
Post your results.
