The connecting rod bearings let go on my 8 hp and now I need a new block, crankshaft and pistons. Does anyone know what other models and years used the same block?
Thanks for the suggestion. I could not find any cross references. I have a few motors laying around 7.5 and 6 hp and was hoping some of the parts would be interchangeable, but I guess not. They all seem to have different part numbers.
I will try and find a used one of the same vintage.
As a unit, the 7.5 and 6hp powerheads will bolt up, but the 8hp block was unique in that it had a larger reed plate. So, if you don't mind giving up a pony or two, find a complete powerhead. If you want all 8 ponies, then only an 8hp will do...
I haven't been that deep in those years 6-8hp & as Chinewalker says the reed valve plate is different on those 8hp, BUT only from 88 to 90. The 6 & 8hp reeds were the same from 84 to 87. If you had a mismatch, there could be the possibility that the intake manifold & reed assembly may interchange off the blown 8 onto a 6hp block.
Thanks for the info. I do have some 6 hp motors laying around, wonder if they would work. I looked at the part numbers for the block, crank and pistons and they were different from the numbers on my 8 hp. I guess the only way to tell is to rip a 6 hp apart and compare.
