Need a 2.4 V6-200 Flywheel....Ack!
philbur
During the tear-down of my old 200 in the fall, I needed to "slightly" heat the flywheel hub to remove it (having snapped a Merc puller and stripped another) and I knew that I would end up killing the magnet ring located under the flywheel hub....not the magnet ring INSIDE the flywheel...the one that serves as the hall sensor ring for the trigger....
I had expected that the hub would be available as a aeperate part from the flywheel...but of course...I was wrong....(nice one, Phil...)...
I am now asking for any help in finding a replacement for this part...either a flywheel assembly, or just the hub...then I would be able to get this motor back together and back on my Hydro, where it belongs....
The flywheel has a specific designation number...which in my case is #.462
Anyone?...Bueller?....Bueller?.....
Faztbullet
Re: Need a 2.4 V6-200 Flywheel....Ack!
You want a whole flywheel or just the hub? Got a stack of them in shed!!:D
philbur
Here is a JPEG of the PDF I created...hope it is clear enough to use as a reference.
Thanks!
Faztbullet
I got it .You want hub or complete. You got pm!!
Faztbullet
Here is pic of hub. Got shed full of parts flywheels,cowlings,midsections,some blocks I will sell but mostly keeping for my service stock.
