Need 4 wire tilt/trim switch
alldodge
Not going to find a single switch that can do both functions with current wiring configuration. There is only 3 wires. The trailer function bypasses the trim limit on the drive
The drive limit switch disconnects the up connection when limit is reached. The trailer uses the same wire from the handle, it just jumps pass the limit switch.
You can bypass the limit switch and just use the handle up/down for full up while running. Just have to remember not to go to far up when the motor is running
alldodge
Well learned something new, thanks. So it has a built in bypass wire
