need 15 inch rims .
canman
hi everyone . will a gm . ford , or chrysler 15 inch rim fit a calkins trailor ? i would like to replace the 14 inch rims and put on 15 inch rims . thanks .
bruceb58
Re: need 15 inch rims .
Usually just depends on the bolt pattern.
I do suggest getting new rims. Buying used rims is a gamble that isn't worth the price difference. You have no idea what abuse a used rim has gone through. New rims are cheap
tashasdaddy
you also have to consider the center hub hole. they are different sizes. voice of experience.
ondarvr
It also depends on what you want to do. For matching wheels to your tow vehicle you may need to use non trailer rims, if you just want new rims, then price tire and wheel combos.
bruceb58
Yes...have seen that myself as well. Way back when, bought a wheel for the spare...fortunately, did realize that the hole was too small in the new rim before we actaully needed it.
tashasdaddy
i was matching ford ranger tires, ended up taking a dremel, with a cutting bit, and just kept going round and round till it fit.
bruceb58
That is essentially what I did too.
Silvertip
Car wheels and trailer wheels are not made the same. Trailer wheels have zero offset meaning the hub is directly in the center of the tire tread looking down on the wheel. Rear wheel drive wheels have the hub offset toward the back of the wheel while front wheel drive cars have the hub offset to the outside of the wheel. The point here is that the offset may cause tire to frame or tire to fender interference. Additionally, the taper on lug nuts may not be the same since metric dimensions have steadily crept into car designs. A wrong lug nut means a lost wheel. Because it fits does not mean it works.
