Navigation lights vs. anchor lights
cutloose442
I have a 17' Lowe Roughneck. It has a white pole light (360* visibility) on the back and a red/green light on the front. Is the back light the anchor light and the front the navigation light? Should I wire these so both are on at the same time or only the red/green light on while underway and only the back light on while anchored? My Tracker has a rocker switch. In the down position it says anchor and the up position navigation. However, whether it's up or down, both lights are always on. Is this right?
JB
Re: Navigation lights vs. anchor lights
Use both lights when underway and only the white light when anchored, cutloose.
Not sure about when adrift, but I suspect that is a navigation situation calling for nav lighting.
Silvertip
Your switch is wired wrong. There are two types of switches but I suspect yours is an ON-OFF-ON type with three terminals on the back. That type of switch requires a diode to serve a blocking function as shown in this diagram. If its missing, Radio Shack has garden variety diodes for just a few cents. Note its orientation (polarity) .
Reel Poor
When you are adrift you are underway but not making way. This situation requires all proper navigation lights.
JB
Well, sure, RP. Good point.
If we get technical about the term, what we so commonly call "underway" was originally "underweigh", meaning the anchor is weighed (up).
cutloose442
Thanks silvertip. I was starting to wonder how to wire that up.
Boatist
Under way as defined by the Coast Guard is not at Anchor, Not aground and Not tied to a dock.
Drifting is underway and requires all navigation lights on.
Something to think about is when Drifting You are underway. Even with all the motor off and not making way you can be considered the GIVE WAY vessle. It just all depends on the angle of the two vessels.
A boat trolling toward you off your Starboard Bow is the stand on Vessel and You are the Give way vessel.
Does not sound right but that is the way it is.
Luckly in the ocean or large body of water the trolling vessel always seem to steer around as long as he see you.
I/O WALDO
I like to use a double pole,double throw,center off,lighted marine rocker switch without a diode.Gives all the connected lights full voltage/current.
95yj
Another point here is that anyone who doesn't know what lights they should have lit, when, should really take the time to run through one of the online boating classes. There's a lot of free ones out there and they only take a couple of hours to run through. Even though we all know how to drive the boat and have been doing it for years, there's information like this stuck in there that everyone who is sitting behind the wheel of the boat should know.
Reel Poor
Thats debatable. :'(
