Silvertip
Honorary Supreme Mariner
- Sep 22, 2003
- 28,772
Re: Navigation Light Alarm Panel
Learn more about what? LEDs, or ??.
As for discussing or debating, I suppose one could say I'm doing neither but rather I'm lecturing. This thread has had some suggestions that electrically won't work yet there seems to be reluctance that ohms law doesn't apply here. In situations like this I tend to prove the concept with a practical example. I'm merely proving that you cannot add a resistive element to any circuit without affecting its characteristics (in this case light brilliance). After I took the pictures of the series and solo bulb, I dug out a 12 volt relay and inserted the coil in series with the lamp because someone had suggest that as a solution. As expected, the bulb would not even light because the resistance of the relay coil was much higher than the bulb. Just trying to clarify some misconceptions here.
Electronic theory is not learned over night. Most technical colleges have a two year "electronic technology course" that results in an Associate Degree. Or you can knock yourself out with a four year EE program at any College or University.
As a brain teaser -- How would YOU test a handful of fuses given to you by your boss for evaluation?
