Nav Lt/anc Lt
PrplGld
Hello, relative newbie here. I have my first bass boat and trying to get it into shape, none of the electronics work. There's a button with "NAV LT/ANC LT". I'm sure NAV LT means navigational light, but what does ANC LT mean?
anchor? ancillary? :confused:
Thanks for any help :redface:
Drowned Rat
Re: Nav Lt/anc Lt
Anchor. Your Red/Green light and White anchor light should all come on when in the "Nav" position. Only the White should light when in the "Anc" position.
PrplGld
Re: Nav Lt/anc Lt
Oh, ok, I see. The white all-round light on the stern is the "anchor light"?
SuperNova
Re: Nav Lt/anc Lt
When the red and green on the bow are on...then it's a Navigational light...when the red and green are off, it's an anchor light...thus the reason for two positions on the switch....the stern light (the white all-around) should be wired to both poles of the switch and the bow nav lights (red/green) should only be wired to the "nav" side of the switch.
Stan
PrplGld
Re: Nav Lt/anc Lt
Stan
Yes, that is your anchor light.
Ok, thanks guys. I've got to rewire everything on the boat, at least the foam and fiberglass still work :(
