mystery water pump
david4001
i have a 1983 Johnson 9.9, model j10rctr. when I removed the lower unit to repair the water pump I found an unusual situation. there is a hex nut on the drive shaft above the wear plate with what appears to be an impellor with a hexagonal hub. I thought I would see the usual slotted hub and drive pin. does anybody have a clue? the nut is on the shaft where you should see a flat spot and drive key.
Honorary Supreme Mariner
Nothing strange about it.----Sounds like the hub of the pump seperated from the rubber.---Install a new factory impeller and put it together again.
F_R
Yeah, had me wondering for awhile. I believe the "hex nut" probably is the separated impeller hub, not a nut. Pull it off the shaft and install a new impeller in the usual way.
HighTrim
Ive seen some aftermarket impellers separate like that a few times. Few years ago though, so I think they have rectified that issue they were having.
