Mystery Vacuum Hose on 4MV
gjcombs
Where do you think a hose goes that connects to this port? I have a Rochester 4MV with an unconnected hose end that is capped off.
It is not the sight tube and not the vacuum break.
See attached pic.
littlebookworm
Re: Mystery Vacuum Hose on 4MV
If I remember correctly, that's for the hose than goes back to the mechanical fuel pump. It's the "dump" hose in case of a diaphram leak in the pump. If you have an electric fuel pump, it's not needed and would be capped. Hy
cr2k
I believe it goes here and is part of the vent. There is a short elbow hose that goes on it. Look for the blue circle.
gjcombs
That connection is made already. It is a clear "sight" hose.
gjcombs
That is for the sight hose.
The one I am talking about is on the throttle body. Here is another pic. This is not the same model as mine, but does have the nipple.
Gary H NC
If it is capped off and you already have the fuel pump sight hose hooked up then that port is not needed.Leave it capped.
gjcombs
Thanks. "Capped" is sort of a formal word here. There is a hose connected there and a piece of a twig shoved in the end.
It still may need to remain there, but made me think I needed to find a home for the end. Or, at least find out why it is that way. :)
