Pleasure Boat Junction
- Sep 29, 2008
- 44
I explained this to the local evinrude repairman, and he said he has never heard of this happening before, and has no idea what the problem is.
http://www.youtube.com/watch?v=P7OLnbQqEMQ
This is the 1970 evinrude triumph 60hp that I posted about a couple of weeks ago. The video shows what is happening with the sparkplugs as I turn the ignition on and off and crank the engine. As noted in previous post, engine will only run on one cylinder and pops and backfires like it is out of time when power is applied. That sizzling sound the spark plugs make can occasionally be heard coming from under the flywheel, probably from the points.
Sparks were noted jumping from the coil to the ground. I assume this means it will problably need a new coil, but I don't think the coil is the cause of the problem shown in the video.
Anyone had this problem?
Photo is of the side of the engine
