Texasmark
- Dec 20, 2005
- 14,891
I spent a few minutes looking for access to the archives and I couldn't find them...help would be appreciated there, but not the issue.
Last time I was out (Mayish timeframe) after a stellar hour or so (off and on) of my usual blasting around the lake at WOT like I like to do, my trusty '02 3 cyl 90 got cranky at the dock when I started it to load it onto the trailer...wouldn't idle long enough to put it in gear and give it some gas.
Last couple of days I started going through it and found a couple of issues: Fuel and spark.
The following happened today in the driveway, 80F on muffs....pee was stellar.
1. Fuel: I found that the plastic linkage that controls the butterfly valves in the carbs is worn to the point that you can't force the valves fully open. In the process of fooling with that, the throttle rod came out of the holder (apparently worn in need of replacement) on the throttle cam and the engine went to some sort of wild rpm's......tach pegged at 7k on muffs no load. Was like that for 2-3 minutes. I tried turning the key off on the remote and it had no effect so I tried to pinch off the fuel line and that didn't work, so I went over to the throttle cam and backed it off manually (not connected to remotes due to malfunction of bushings it seats in) till I manually got the carb butterflies closed and was able to shut her down. The key on a brand new 2000 remote failing (where it worked just fine other than this rpm runaway) is one thing, but not the center of attraction here.
So now, I know a stock Merc 3 cylinder will run over 7grand for over 3 minutes "without puking it's guts" with no load on the engine. So when I get her fixed, the 5600 to 6000 I should be running under load will be a walk in the park.
2. Ignition: First of all I eliminated fuel as a culprit as I disconnected my fuel line to my built in tank and put it into a container of fresh gas that I bought a couple of days ago.....changing from fuel with Sea Foam that was about 6 mo. old to fresh straight fuel had no impact on the problem. Additionally, I changed my low speed carb. needle positions from the recommended 1 1/4 min setting to a full 2 rev setting to ensure that a lean mixture had nothing to do with the "sneezing" I will talk about below.
Plugs really sooted up today and I put in 2 sets of new plugs with no effect. Lots and lots of exhaust smoke.
First off I had a very hard time controlling rpm's today even with the linkage problem. I fixed the linkage so that it was in a constant position and the engine continuously surged anyway. Like at idle, minimum I could get using the idle set screw on the throttle linkage, was 2k.
Problem other than that is sneezing on a precise regular basis, about once per second and when it sneezes a blast of exhaust gas blows out the tail pipe. It was obvious that one cylinder was loafing, but finding it was a daunting challenge I haven't as yet mastered. All this happened before and after the 7 grand rpm runaway with no change.
I ran on one cylinder at a time and found the #1 cylinder to do the sneezing and 2 and 3 would labor the engine along as one would expect with 2 of 3 cylinders disconnected. I had the plug wires of the other 2 capped on plugs that I had grounded externally and the non firing plugs were still installed in their sockets with no fire to them....dead cylinders.
I then moved the CDI from #2 to #1 (plug wire and trigger input) and thought I had it nailed to a trigger input problem to #1 but that result is inconclusive.
Sooooooooooo you guys, want something to occupy your time when you feel bored and "nobody loves you (grin)" chew on this if you choose.
I did run the Stator resistance test with the ohmmeter for all 3 CDI's and it was 708 digital ohms exactly for all 3 with a book value of 670 to 710. The input terminal resistance tests for all CDI's were identical.
One CDI is about a year old with PN 827509-A9 whereby the other 2 are original '02 versions at A8's.
Ok guys, do your stuff.
Thanks,
Mark
Thanks,
Mark
