my starter started smoking today... one of the bolts from the bottom of the starter
kelplin
one of the bolts from the bottom of the starter is unbolted and im wondering if thats what is making it short out... just installed new batterie cables, was running ok, now i cant figure out the year, the serial # is gone... also broke a piece of the carb. i have pics, would like to get a manual but not sure the year.
fireman57
Re: my starter started smoking today... one of the bolts from the bottom of the start
it looks newer. Mid 90's maybe? Make sure that the hole the bolt worked out of isn't stripped. If it is don't trust it. You may have to have it retapped. The starter will wobble and if the wire makes contact with another piece of metal it will spark!
kelplin
i cant figure out how to get the starter off??
fireman57
Mine is three bolts. One you have to take the carb off then there is one at the top that I use for a ground and one at the bottom.
boobie
If the starter was smoking it should be removed and sent to a rebuild shop to be checked out.
kelplin
anyone have any idea of how to get the starter off... i unbolted everything i could see and the starter bracket will not budge. I would buy a manual but have no idea of the year.
boobie
Look way down to the bottom of the bracket. There may be one down there.
