My rig died at the ramp...yikes!
airdvr1227
Ran up to a local lake tonight...days like this can't be wasted. We did our usual routine...I backed down the ramp...hopped out...she tries starting...runs a couple of seconds and dies. I figured it would start so I pull the trailer out and park. Come back...still dead. Turns over but won't catch. Hmmm...never did this before.
I opened the engine bay and pulled off the arrester thinking it must be flooded. I smell no gas. In the meantime things are starting to get pretty busy with people wanting to retrieve. I clogging up a lane so I figure I've got to get out of their way. Started walking her around to the other side of the dock. About halfway around somebody just pulls in. Now I can't get to the dropoff side and I don't want to go back to the ramp side. Fortunately I explained my predicament and they moved forward so I could tie off and try again. Turns out a ground wire came off the riser. I was just getting ready to get the trailer when I saw it. Reconnected and it fired right up. Had me sweating there for awhile. I could feel the scowls of the folks wanting to retrieve.
Bifflefan
Re: My rig died at the ramp...yikes!
IMO people that get cranky because someone else is having a problem are just a buch of a**holes.
Its not like you were being a jerk and sitting there for no reason, you had a legitament issue and if they cant give a little then to H**l with them.
But this is me...
WAVENBYE2
But this is me...
I agree!! Glad you figured it out!
SeanT
With my old IO I got into the habit of putting the muffs on in my driveway and letting the boat idle while I got everything else ready. That way I knew everything would be tip top coming off the ramp. Mainly I did it in case the ramp was busy, I could drive off the trailer and get out of the way quickly without stalling at a bad time.
Glad you got it sorted out!
airdvr1227
I was doing that too but she never had a starting issue all season so I let that part slide. My normal routine was to make sure she was running before I released her from the trailer.
Bob_VT
Check your fuel pump, water separator, fuel screens....etc
bigskiohio
Master Chief Petty Officer
same hear check all your fluids, outdrive oil needs checked everytime and run on muffs, charge battery , makes for a lot less tension at ramp. if my boat sits for a few days it takes a little cranking to start so that prerun gets rid of that at ramp.
