JIMBALLS13
- Jun 8, 2017
- 4
My first post on here, not the best on forum etiquette, but here goes. My "buddy" rebuilt my 4.3, SN 0F873698 . Gor back 3 years after drop off. Had to get police involved to just get back. He did "finish" the motor before he gave it back. Switched fron 2bbl to 4bbl 1409 edelbrock w/2114 intake. .30 over, 3 angle valve job, hr266 comp cam. Oil filter leaked like a siv, fixed that. First run, lots of hesitation, rejected and changed rods, almost all hesitation gone. Had a high speed high rpm backfire issue. 75% throttle ran fine, getting 52mph on dash speedo. That's about where it ran before, but if you gAve the last 25% it would backfire like hell. Thought it may be timing due to new cam. Checked timing it was at 8.5 btdc in base timing mode. TBV ( I grounded the p/w wire to ground. Advanced it to 10btdc, had more throttle response but same problem at high speed, low load. Did a full tune up on ignition system. Changed cap, pickup, rotor, wires and plugs. Now I'm only hitting 4000 rpm. I was hitting 4700 before ignition tune up. I'm going to time back to 8.5 to see if it helps. Main issue is my "OIL FULL BILGE". I've read a few threads on this, but have a few questions. Do balance shafts and non balance shafts use the same oil pan? OK I'm at the bar and steak just showed up. I'll finish the questions in next post.
