Re: My last week project, Re-did the living room..
ob : "is that a niche I'm seeing to the right of the window " <br /><br />ehwha? "niche" ..had to go to webster.com for that one, so the answer is no, it's just 4 pictures hung on the wall. I got a can of spray paint, painted the return air vent, picture frames, and the door frame outside of the picture all to match.<br /><br />JamesCoste:<br />this is the first floor I have EVER put down, it is not difficult if you take your time. You need the install "kit" they sell, it's a tamping block with the grooves in the right spot not to break stuff, and a pull bar you hammer the last piece in a row to.<br /><br />I went to the library and got a "hometime" video on the instalation, watched the 5 minute video and it showed me everything I needed to know, you have to see someone do the technique for it to make sense on how to install.<br /><br />The tricky part is the END of the room, as you have to hinge the stuff to install it, notch around door frames and slide under, gets a bit tricky figuring out the puzzle, but anything is possible.<br /><br />When i got to the end of the hallway, I had the last 1' to go, couldn't figure out how to make it work, went to bed, laid there for an hour, figure out how to slide the pieces to gether and then went to bed
