My humble request for admission to the Starmada: 1972 21' Chieftain OB
jbcurt00
Re: My humble request for admission to the Starmada: 1972 21' Chieftain OB
^^ Bump ^^ for a health & happiness update on u & the Chief......
ShowMeGuy
I'm with JB... Whats up.?? Maybe you are training to be on that TV show I seen last night call the "American Ninja Warrior"? Those guys got some skills!
erwinner
Hey guys! I hadn't seen that my thread had been bumped until just now.
I'm doing pretty good, all things considered.
Did have a checkup with the cardiologist last week and the echocardiogram showed no signs of the tumor returning, so that's pretty great! Hopefully won't have to go through that crap again ever! I lucked out as they were able to repair the valve instead of replacing it. The plastic ones are only good for 20 years and pig's valves for 12. I did not want to go through that again 2 or 3 times in my life!
As to the Chieftain, not much has been done except show it to my friends and evict a wasp's nest. I did have to remove the upper windshield to fit it fully under a carport and be within code regulations. :facepalm: That took a little while but the code officer was very easy to work with on an extension.
On the plus side, my brother is moving back from Costa Rica soon, will have a lot of free time, and wants to help out on the boat!
I've still got a few months before I'll be able to really rip into things solo, much less be out on the water by myself, so with his help hopefully we can at least get the transom pulled and replaced by the time I'll be able to feel comfortable on the water. If the Merc 115 on it right now is dead I'll at least be able to clamp on my much, much newer 15hp Merc and be able to put the boat out to camp. And check for leaks. :D
My birthday is in a little over two months and that marks almost exactly 6 months from the procedure. There also happens to be a 2 day music festival at the local lake. With any luck she'll be floating there under some kind of power. But I'm trying to keep my expectations realistic, so it's not a plan, so much as a dream. I did join a gym for the first time ever as it turns out your upper body turns into jello after 2+ months of non-activity!
GA_Boater
Thanks for the update, ER. Get those muscles back in shape. With your new found strength and brother the dream can become reality. I'm so glad for the improvement. Now don't be a stranger, Buddy.
jbcurt00
Congrats on a clean bill of health from the cardio doc. Texas has a VERY long boating season, so take your time & get closer to 100% and w/ your bro's help it'll come together in due time:)
erwinner
Not much real progress, but I did find a 10' tall gantry and 3 ton chain hoist on craigslist for $60 so the Tower of Power will be coming off soon and the transom wood will be getting replaced.
Slowly but surely!
barato2
hey ER, glad to see you back around! and glad to hear you're healing up enough to start on the tin tub. transom is a great place to start....i keep running into things with my boat that can't be figured out or finished til i get the transom in for good.
and THANKS BUDDY for reminding me that the tools section of CL is also a fertile place to expend my time and $$....:rolleyes:
jbcurt00
Not much real progress, but I did find a 10' tall gantry and 3 ton chain hoist on craigslist for $60 so the Tower of Power will be coming off soon and the transom wood will be getting replaced. Slowly but surely!
Great score on the gantry, it will definitely be handy for more then the motor.... What's the countdown to music fest & your birthday?
erwinner
Only about 3 weeks. Might just be the little boat and a tent this time. I got the little tinnie out for the first time two weeks ago and it felt pretty good. The Merc fired up on the second pull after not being started since February, so I'm pretty stoked about that!
They really don't tell you just how long you'll be laid up for. They try, but there's no way to really know how you'll feel until you get there.
I hope none of y'all have to find out!!!
jbcurt00
Yep, hope to never need the big ole staples thru the sternum :redface:
If you're pull starting an outboard, even a small displacement one, you're healing up pretty good ;)
Tinny & a tent sounds good too! Any day above ground I reckon! :)
