my compression sucks?
bryanhumpy
just tested my compression on my force 120 L-drive.
#1 122
#2 97
#3 65
#4 120
so what now? am I screwed or what?
any one rebuild one of these?
is it beyond help
I'am so sad
someone help please
MAW31
Re: my compression sucks?
ya, that kind of discrepancy is very bad.
are you using a reliable compression tester?
its very probable you've got internal damage and yes, repair will be necessary.
take the heads off to have a looksee at the damage and assess from there.
bryanhumpy
Ya brand new compresssion guage just purchased.
dont know if i am able to tear her down never done a powerhead before.
I guess what do i have to loose..... summer's on the way
the other option is to push the boat into the street and let the cops pick it up...lol
well i wanted a project ....hahahahahah
I've heard about this seafoam stuff
or is that just wishful thinking
boat has been sittin for about 2 years
kend301
If the boat has been sitting pull the plugs , Spray WD40 into each cylinder a n rotate by hand , do this 2 or 3 times and put the plugs back in , let it sit for 2 days and recheck compression after running . Rings just may be stuck .
Frank Acampora
Since two cylinders are bad--forget about wasting time with seafoam--it will not improve.
So: since two cylinders are bad, you may as well bore and replace all four for a brand new engine. Approximately 500 in pistons, 200 in overbore charges and another 50 for gaskets. Price for pistons I am quoting is Wiseco. They come complete with rings and wristpin.
Since you never did a powerhead before, figure 10 hours to disassemble and 10 to reassemble. No special tools other than a torque wrench and flywheel puller are needed. If you can tie your shoelaces, you can do the rebuild.
Oh, yeah! Helps a bit if you have access to a hydraulic press to press out the wristpins.
bryanhumpy
OK.. i'm ready to give it a shot..
yes i can tie my shoe laces
i'm pretty mechanically inclined... (famous last words) lol
I'm gonna order a manual tonight. thanks for the advice
JustJason
run some mercury power tune through it as perscribed on the can. If the numbers don't go up and be even then you have a scrapper.
