I've attached some pictures, one of the terminal block showing the relays, one of the trim motor and one on the trim piston that shows a rusted bracket.
1) When I hit the trim switch up, I hear a relay click, when I push it down no relay clicks. I swapped the position of the relays in the box and the same results up-click, down-no click, this tells me the relays are both good.
2) When I pierce the wire close to the motor (why only two wires for two positions?) I do measure 12V when i switch to up (click), 0V when down (no click), yet no activity with the motor.
I get the feeling that there is an interlock problem, somewhere along the line this motor was tilted down too far and an interlock kicked in and is frozen open, could this be?
Thanks in advance.
Frank
Thanks in advance.
Frank
