Ok folks here is another issue. I run the engine for less than 5 minutes and the temperature gauge jumps up to 190deg (I shut it down when it indicates anything much over 170, since i used to run it at about 160). I have attached some photos;
1) pic #6 Water pouring out of weep hole, which i thought was a good indication that all would work well.
2) pic #7 Water coming out of seam at lower unit, this doesn't look right to me.
3) pic #9 water coming out just to the right of bolt and about lower unit oil drain vent screw.
4) pic #11 stream from underside of the top of the lower unit.
5) pic #13 Here is where I monitor the temperature.
Any ideas as to what to look for to get the correct regulated (thermostat) temperatures? I was told 160 is the correct temperature.
Thanks in advance,
Frank
Thanks in advance,
Frank
