My 84 Mercruiser 140 overheats!
bperry
I took my boat out for the first trime in 2 years on Sat. It started great but immediately began to overheat. Any ideas where to start?
4Winns2
Re: My 84 Mercruiser 140 overheats!
When the last time the impeller in the outdrive was replaced?
Thermostat okay? Do you have a service manual for it that you can check a list of probable bad spots for overheating?
Get whatever is causing it fixed. I just blew an inlet water hose and spun my crankshaft bearings which means I'm flipping engines, again.
Ayuh,....
Change the Impeller in the lower unit.....
