My '55 5.5 outboard
Seahorsefan
Hello gentlemen,
I bought a 1955 5.5hp for $25 and plan on attempting to get this oldie running I hope. There is a small diameter rubber line that goes from the top to the bottom cylinder that is cracked and likely needs to be replaced. First, is this a vacuum line or a line related to fuel? Second, does anyone have a part number for the rubber o-ring for the shift rod seal or an o-ring size that would work?
Thanks for your help!!
Crosbyman
oring liklely 0301877 best to get OEM orings ... see utubes on how to replace it it not familiar how to.
identical size somewhat hard to find :-(
That o-ring is very common.-----Still installed in 2007 motors as well.----Local boat shop would have that o-ring in stock at about $4 or $5
Crosbyman
btw is the gc getting water ??
if not no need to mess with the GC do pressure test. if it holds pressure and vacum it is ok . just do the impeller carefull with the brittle carbon seal on top of the drive shaft .
the book CHEAP OUTBOARDS is a good one and covers the 5.5hp
ct1762@gmail.com
Master Chief Petty Officer
the hose you speak of is extremely important as it lubricates the bearings! ps sorry didnt see the pic
