My 1975 45hp Chrysler model 454BC sat for about 10 years with a bad lower end. Fixed it after 10 years of procrastination. Used the boat a few times and now the engine has crapped out. It was beginning to idle rough the more that I used it and then it began giving lots of problems. Here's the info:<br /><br /> fuel ball is good, lots of gas in the sight glass at the pump and I can squeeze the ball and get fuel to come out the hose at the carb, all new fuel hoses, cleaned out the carb and it worked good. Suddenly it won't start at all, I crank it over and I get some gas build-up at the carb but it doesn't seem to be getting to the plugs. I checked the lines that run off the carb (the ones with the check-valves in them and they were dry and empty) and the plugs have spark but they both don't seem to be getting any fuel from the Carb. When I crank it over it just backfires every few seconds and then the whole engine seems to lock. I have to re-start cranking it again and then it turns over fine although it seems to really be drawing a lot of juice from the battery. The battery was good and fully charged. I think that it is a fuel problem since the plugs should be soaked after all the cranking, right? Where do I begin? Please give a frustrated guy some more knowlegeable advice and it'd be greatly appreciated.
