boltonranger
- May 2, 2004
- 204
First let me say this forum is invaluable to folks like me.
I am a shadetree guy; and have been able to repair my engine and boat because of you fellas.
1988 Stingray SVB 176 ; 3.7 merc I/O Alpha One
So here it is.
First trip out 2 weeks ago. I had drained out the old gas from my tank; put in fresh (although all had stabil)
and fired up the boat at the launch. Mechanical fuel pump needed time to crank the gas in the line and before I knew it my battery was wheezing and quit. Kind fellow at the launch helped me. First by handing me a spare battery to lay on deck and connect to mine with jumpers. Not enough juice. Next he fires up his boat and jumps mine to life. All good I thought.
Noticed as we were out that the battery still was slow to crank. Since my boat is fairly well tuned it would fire up.
So between then and now I bought an AGM starting battery since the old wet cell one was at least 6 years old.
OK so went to go out this weekend and figured test on muffs first couldn't hurt - So I started the motor and noticed 17 volts on my panel gage. Hmm. So I got my electrical meter and tested running and off. 12-13 volts with engine off. 17.6 while running at idle; engine warm now. No smoke / electric smell; just higher than normal voltage. Nothing bad looking over at the regulator on the block by the way.
I'm thinking I did my system harm by jumping... would you agree?
Wondering if regulator is shot and it's time to replace or buy a kit and retrofit.
Some questions:
I've seen an aftermarket watercooled regulator online for a little less than the merc one.
It says right at the top of the web page "Do not use with sealed battery or AGM battery."
I did not notice regulator trouble until I installed the new agm battery and ran on muffs - Coincidence?
Did I kill the regulator with the jump at the launch or the new battery?
Should I assume the No AGM also follows for my existing Merc regulator?
Should I throw the old battery back in and check charging voltage?
Is there a procedure to bench test my existing regulator?
I charged the new AGM battery the night before.
Incidentally I did not notice high voltage out on the water the last time out.
It may have been - but I did not notice.
So time and money being what they are I'm turning to you guys for help.
Can you answer my questions?
Thanks.
-br
So here it is.
Some questions:
Thanks.
-br
