Ethanlooy
- Apr 15, 2013
- 15
My 1999 Evenrude 40hp 4 stroke wont run right. I know that I should have taken out all the two year old gas that I had stabilized but I thought maybe it would be ok.. it ran good on the maden voyage this year for about 30 min until it started bogging down bintermediately and eventually forcing me to bring it to an idle or it would stall on its own. Then it started getting progressively worse as I limped my way to the boat launch. If shut off or stalled, it will start right up and run fine for 10 seconds but now even if I dont or I do give it gas it will eventually start choking randomly and sparatically until I shut it off for fear it will hurt itself. I tried adding sea foam and 3 times more fresh gas than it had in it. Still the same and getting worse. Went home. Ive replaced the high pressure fuel pump and cleaned out that reservoir, changed both filters, checked the fuel pump... the diaphrams look good. Tried running a new gas line from fuel pump directly into fresh tank of gas, no change. Checked all fuel injectors, tried to soak them for a bit in carb cleaner and tapped some power to them while in the carb cleaner to have them open. Running out of ideas.. gonna try replaceing every one of the fuel lines in the engine next in case the old fuel I had contained Ethanol. Any ideas guys?
