frankk
- Aug 31, 2003
- 63
OK, I will admit that I am not a mechanic (but love to learn) but do know my way around my Merc 5.0 / Alpha One.
I have a 90HP Johnson 4 cycle that was converted to a 2 cycle, having now to mix 50:1 gas. It was done maybe 10 years or so ago, and although it runs strong, it still smokes like a 2 cycle. On top of that the bottom end is leaking quite a bit causing it to overheat at low idle. I would like to convert it back to a 4 cycle, and understand that might not be easy. Cannot seem to find any info on the net on how to.. I do think that if I convert it back to a 4 cycle some of the smoking will go away and maybe fixing the leak will stop the smoking and the overheating will go away. Here is the link to the leaking. Look to the left of the muffs. That vertical line is actually water leaking out when I was running water with the muffs on. http://electronicinstrument.com/pee.jpg I do think that I would want a mechanic to do this work for me though. Other then that the motor works well. Any thoughts or suggestions?
