TinCocodrie
- May 1, 2008
- 8
Hi Group
new to forums and could use advice
I have bad multifunction gauges on my boat- two 1998 150 saltwater series. I like things simple and am going back to standard gauges. I'm going to install Teleflex Lido Pro gauges in place of the multifunction units. I know the trim is connected to the tach and if over 30 deg the auto pump does not work. When I unplug the tachs and the connector is open in free air will that tell the oil system to not work? I'll make sure the connector is properly supported under the dash and can't ground out. I have a factory engine service manual and the wiring diagram rigging instructions but no diagram of the oil system.
thks
TinCocodire
thks
TinCocodire
