Mushroom Anchor And Mooring
pbuzz3323
Im going to moor my boat next season on Long Island as Slips are nearly un-obtainable. I have a 2003 24' searay and code requires a 250lb anchor. I found a 400 lb anchor but cant get shipping charges until I buy it...Is anyone familiar with this shipping process? My marina wanted 720.00 for 250 Lb anchor so a New 400 LB for about 400 bucks is Ideal..I found it at Boatfix .com If anyone knows of another store to get one and the cost it would be appreciated..Thanks
jay_merrill
Re: Mushroom Anchor And Mooring
Find out the packaged dimensions of the 400 lb unit call a couple of freight companies. With the dimensions and weight, they will be able to tell you what they would charge to ship. Given the size/weight of this item, you will need to have a forklift available at the receiving end and the shipping will be less if that destination is a commercial building/location.
Just out of curiosity, how are you going to get a 400 pound anchor out to your mooring site and in the water?
tashasdaddy
call : 609-625-9424 that's boatfix.coms phone # if they won't tell you the shipping cost before purchase. go somewhere else.
Texasmark
I like the "Why not make your own idea". Not only may you save some money, but you have to get that thing out to the desired location and sink it. How you gonna do that?
Would think a little creativity and a few bags of Sacrete with an embedded rebar loop would do nicely for a fraction of the cost of what you are talking about. Rebar is high tensile steel and resists corrosion (other than surface skin-over) very well.
400# at 80# ea of Sacrete is 5ea $3 bags. You could build a square wooden box made out of any kind of wood (new, old, doesn't matter....will just be a form for your concrete till it sets up), $30 ought to cover that.
Get a 4' piece of 3/4" rebar, for $5 and bend in the shape of a horse shoe. Finally get a farm tractor inner tube (probably used and free as you are only going to use it for moving the anchor out to location) of sufficient size to support 400#.....a 16.9 or 18.4 x 38 is a good place to start. These tires are used on tractors in the 100 hp arena and you want a large diameter to assist in keeping the thing from tumping over on the way to the anchoring site. Any full service tire store close to agriculture will have them. Then you will need another piece of plywood to fit across the inner tube to support the anchor while building it up and floating it out to the desired location. Another few bucks.....geez we're at $50. Not bad.
Take the materials and the inner tube to the beach and make the anchor right there. Little or no wave action at the selected site would certainly help. Embed the rebar till only about a couple of inches of loop are on top of the crete. The ridges on the bar will keep it from pulling out when setup.
Maybe you could plan an overnight beach party and make this part of it; get the kids involved if you have some little "tykes". In the morning it would be ready to go.....especially if you get Sacrete with calcium in it to enhance curing in cooler weather.
I'd attach your anchor chain with a clevis of suitable size. You might take some monofilament fishing line (won't deterioriate) and secure the pin in the clevis so that there is no chance of coming unscrewed. Course when you tighten the screw, you put the clevis in tension which helps to keep the screw in place like a lock washer would do on a conventional bolt-nut fastner.
After carefully towing to the desired location, slowly let the air out of the tube and while holding onto the attached anchoring chain/line, obviously paying out chain as it goes down, guide it down to the bottom and let her sit. I'd do this carefully as the crete would still be a tad "green" and you don't want to disturb your rebar.
If you don't think 400# is enough, just add more Sacrete. Grin
Shouldn't take long for that to embed it's self in the bottom. Walla done deal.
My idea
Mark
jay_merrill
I like the above idea but have a couple of suggestions. Use the heaviest rebar and chain that you can. As wind moves the boat around the anchor, lighter chain will move more and lighter rebar will wear more, possibly breaking due to side loads.
I have used a similar set up for use as ballast for outdoor entertainment stage rooftops. We poured concrete into empty 55 gallon drums to make ours and used rebar that was too small the first time we did it. Granted, a 55 gallon drum full of poured concrete is a lot heavier than what you would make but, we found that the rebar would break when lifting the barrels by the loops with a forklift.
Also, you can just hook the rebar through the end of the chain before setting it in the cement to eliminate the need for a clevis.
All in all, a very clever idea though.
pbuzz3323
It gets placed by a marina, They handle all the dirty work at a pretty reasonable price.. I have to use a mushroom anchor as per local town code...I already did my homework on that end of it. The marina it will be infront of charges 20 cents a pound to place it.
Texasmark
I have made and transported several miles with a farm tractor front end loader,without problems, square concrete anchors weighing 350# and only had 1 ea 3/8" rebar for the loop. If you are in doubt get 1" or use 2 or 3 loops of 3/4". 3/4 is easier to obtain and that's why I recommend that.
Mark
tommays
The mooring fields are VERY controlled on LI right down to the surveyor on land guiding the drop ;) because the fields have SO many boats
It is pretty unlikely there going to let you drop down anything homemade
Tommays
pbuzz3323
Tommays
Exactly right..Strict rules here..I have a 24foot searay requiring 250 lbs anchor. Recommend going heavier and found a 400 lb, new for 400$ plus 400 shipping. Lucky me though its located about 100 miles away. I have a F350 so it will be a
100$ trip to get it instead of 400 shipped
