Hi everyone. I'm a first time Boat owner and This is my first post!
I have a 1988 88hp Evinrude SPL. electric trim and tilt. And use premixxed gas/oil 50/1. I only took the boat out once right after I bought it and it seemed to run fine(besides it didn't idle very well) That was almost 2 years ago. Now that I totally cleaned, painted, and made the boat like new I'm having problems with the engine.
1st problem is my engine seems to be overheating. I started it up with muffs and there was water coming from the engine. It was not a solid stream but kind of like a fast dripping. About 1 minute or less later and a Solid Alarm went off. I turned the engine off and just left it.
2nd problem is the Tach is not working. It did work when I bought the boat. I put a new tach in and now its not working? It is getting 12 volts. My battery seems to be charging. Battery was 12.25 before start and @12.5 while running.
So now I'm going to put in a water pump kit and a new rectifier and see what happens.
I plan on ordering all the parts from here on iboats but I'm not sure what to
order. The parts listed on the iboats store are listed for 90hp(thats the same right?) Anyway part #'s and any other ideas to solve these problem would be much appreciated.
Aloha Jon
Aloha Jon
