TG,
I had those things way back in the day but,
I run 4 lectric DR's for many years now and over the years it has evolved into a setup that I like and works well for me and my needs.
Perhaps you might grab an idea or two........
1) Power riggers with a dedicated house battery that isolates from your engine battery with the engine off and charges with engine on and/or with an on-board charger. (I run
this type w 3 batts, 2 house, 1 engine)
2) Using like 4 AWG marine grade wire from battery with a dedicated connection (no quick connect stuff), power both (I have 4) riggers through a single re-settable breaker (similar to
this type) switch (I run 60 amps for 4 rigger @ 10A'ish max/riggers, each rigger has its own bult-in factory 10A resettable push button breaker). This main breaker lives is as close to the battery as you can and has good/easy access.........Wires within 6-8" of battery post I think (might look it up, I forget) the ABYC reg states.
3) After this main breaker switch, all rigger's power goes through a solid state switch (SSR, I use
this 150A type FWIW). This allows you to remotely and globally, from a normal low current helm toggle switch (5A/10A etc), to turn power on and off to all riggers at once. (This/most all SSR's use micro amps to run, mech relay/contactor coil's at this level draw/use too much power for my needs/design, less latching type)
4) The output of the solid state switch (SSR) is where you'll individually tap each rigger's power from of course. Use like 6 AWG marine grade for each rigger run from the SSR output where each run goes to power a twist lock power receptacle (see #5 below)
5) Each rigger has a twist lock (I like
Scotty/Marinco) power connector that allows you to quickly and easily electrically detach/remove the riggers from boat without huge wiring fuss.(when no rigger's are plugged in, I have
LED deck lights that plug in in place I made up that can be powered on/off with that same helm switch above in #3, the outlets are all handy for other uses of course)
