SHOULD MUFFS ON LOWER UNIT WITH WATER BY HOSE SELF-PRIME WITH MOTOR RUNNING?
I have 1998 Stingray 23' with 7.4L, Bravo 1 drive, that we bought used this spring, 340hrs on motor, beautiful boat, clean motor. Ran this year no problems.
Winterizing it for the first time, bought the "Muffs" to go over the water intake on the lower unit.
First, warming engine to allow oilchange via dipstick tube pump we had water on awhile via muffs, then started engine. It took a little time for the water to start coming out thru-hull exhausts...but then was coming out nicely, ran motor 10 min, changed oil.
Next, to circulate antifreeze (eventually) we first had water running via hose into muffs, but at idle to 1000rpm it did NOT get the water to come out the exhaust pipes. I turned up the water pressure some, held those muffs on TIGHTER (while getting soaked from spray out the muffs edges as it was at some moderate pressure) but it seemed the water system would NOT prime, and no water or very little if I held the muffs VERY hard, would come out exhausts.
I wondered, do I have to have the PROP SPINNING/IN DRIVE to make the lower unit impeller start sucking? I didn't THINK so...but why does it NOT "prime" with the muffs on? Is the impeller bad? The boat never overheated or had any problem all year.
