robert.barnes
- Oct 4, 2006
- 62
is a 120 looper supossed to idle smooth or does it kind of chug like a trane i changed the jets from 42 to 43 and it did help every thing is spot on idle is good 700 rpm and it picks up to wide open fine but the idle adjustment still does not want to work that well. i thoght it might clean up the idle but it did not. i can stall it out but it will only increase the idle maybe 200 rpm before the screw tries to fall out. i raised the motor up so the exaust holes r no longer under water this maybe common for this motor i have only had crossflows so i was not sure
