Move tilt pin or use tilt motor?
ashedd
I'm not entirely sure where to post this...
Do I need to even mess with moving my tilt pin up or down a hole or two when I have the electric tilt? I read about people moving the pin to help trim it all out right, but at the same time they have the electric tilt/trim. I'm just having a hard time seeing how the pin even matters if you can set the trim with the trim/tilt motor.
The reason I ask is because my motor is always at a negative trim angle when fully down, the pin could stand to come up a hole or two, but the pin is rusted solid to the transom bracket. I tried removing it with a torch and even started to cut it off with the cutting torch, then I figured it probably doesn't matter where the pin is as long as it's out of the way enough to allow the motor to come all the way down. I could technically put a new pin, or bolt even, in one of the upper holes if I need to.
I can see how it matters with manual tilt obviously, but not with a trim motor.
flyingscott
I put mine in the lowest hole possible and forget about it that way I have the maximum negative trim for hole shot.
hemi rt
We take the pin right out and let the trim set the lowest point the engine can go down, pulls out of the hole a lot quicker this way
flyingscott
You can take it out but if the T/N/T ever fails that is the only thing your motor is sitting against. Some motors can actually hit the T/N/T assembly or push to hard on the tilt ram I like it there for safety.
