mounting motor
leafs
i am going to buy a 7.5 hp evinrude for a trolling motor are (1986) these good motors also how do i mount this beside my 70 hp johnston(is there a special bracket)
ob
Re: mounting motor
The small evinrudes are excellent motors.You can get a nice auxiliary bracket right here at iboats.<br /> motor brackets
andrewkafp
Re: mounting motor
Leafs<br /><br />I mounted a 6 horse so that on the highest notch the cavitation plate is level with bottom of boat. That way you have another 3 or 4 positions to go further into thw water if needed. Retraction is not that important as the motor swings back an locks like the main motor. Make sure you use a heavy backing plate inside boat to stop bolts from ripping through when trailered.
