mounting bolts
enginedude
Does anyone know what the correct nominclature is for the motor mounting bolt that attach the motor to the haul. Im trying to buy new ones but I already purchased one for 40.00 but trying to go cheaper for the second any help would be much appreiciated.
surlyjoe
Re: mounting bolts
do you mean the outboard bracket toggle screws?
enginedude
Re: mounting bolts
well I looked that up and I didnt get anywhere. I cant find those screws for nothing. Its just the screws that you tighted down to the back the bolt to hold the motor on. Thanks for your input
enginedude
Re: mounting bolts
OBJ
Re: mounting bolts
Clamp screw? Swivel plate? What kinda engine you got.....hp wise.<br /><br />EDIT: Better yet....click the BRP link below and then click on engine diagrams. Follow the instructions till you get to your engine and look at the midsection diagram/parts break down.<br /><br /> http://www.evinrude.com/en-US/
OBJ
Re: mounting bolts
OK....that year won't show up at the link. What your looking for are the transom bracket clamp screws and swivel base (this is the part that goes against the transom)<br /><br />Probably you will need to go to a site like isomarine, twincity outboards, seaway marine.....sites that will handle the older stuff. Or, stop in at a local John/Rude dealership. I think replacements are still available. Might even get a good set of used ones.
enginedude
Re: mounting bolts
yea I ordered one of them but very expensive just for one screw was 42.00 but thanks for the help.
