I have a 1995 Sea Ray 195 br which came with back to back seats on both side's & a Fiberglass Floor. I Purchased a New bucket seat & a Springfield fixed height pedestal with swivel & slide, that i want to install on the driver's side. I went to West Marine & they told me to use & I purchased the Garelick SS Toggle bolt anchors & (6) 1/4 x 20 x 2" SS bolt's. I removed the back to back seat & marked where to mount the pedestal without hitting the shift control when i swivel the seat. I drilled a hole (about 6-8" behind the old front mounting hole's) with a small bit & fiberglass came up & so did some wood. I guess this is the Stringer ? So i checked the old mounting hole's & there was about 1/4 - 1/2" of fiberglass & wood below that. THERE IS NO WAY OF GETTING UNDERNEATH THE FLOOR SO SEE ANYTHING. Next i took a hammer & tapped around the old hole's & the 1 new hole & it sounded solid. Then i tapped in front of the old mounting hole's & it sound's hollow. My Question is : Is it safe to drill the rest of the mounting hole's through the fiberglass & into the Stringer & mount the pedestal to the floor with 1/4" x 1 1/2" SS screw's, or try & mount it more forward of the Stringer & use the toggle anchors with the 2" SS bolt's ? The only problem i think with mounting it more forward is it will be to close to the steering wheel. PLEASE HELP !!!
