Motot Beeping
99 Mercury 150 xr6 is beeping while in the run position and while running - on trailer or in water. The engine seems to be running fine. It started after a day on the water tubing, while trailering the boat, it began beeping. Topped off with oil, filled up with gas, now the beeping won't stop.
Thanks for any info :)
Francesca
Faztbullet
Add oil to your fuel before running it anymore as beeping is a oil alarm. Could be the oil gear has failed,alarm module failed or #5 cyl switchbox has a proble,
