Jim Robbins
- Jun 15, 2005
- 85
Hi, I had my 1982 Evinrude 140 hp (E140TRLCNB) blow its head.......so I bought a 1985 Johnson 140 hp (J140TLCO) with VRO system, tilt-trim, controls, and things are not quite the same? My mistake! I was going to put the prop. from one to the other (NO, diferant size prop. shaft). What is the prop shaft size for the 1985 Johnson 140?
What else is different between the motors? Is there a motor weight difference? Is there any other things I have to consider when hooking up motor? Is there a height that oil reservoir should be mounted? What is the Pre-start-up, first start up, ect. any other advice is greatly appreciated!!
Thank-you.
Thank-you.
