The whole problem started when I went to use the boat for the first time this year (it had been sitting for 3 months). When I went to uncover it, I noticed that the trolling motor had a "burnt electrical" smell. As it turns out it had been left in the "on" position the whole time. The motor didn't work. After replacing the lower unit the motor now works but not correctly. I wired it the exact same way the other one was wired (Blue to Blue, Yellow to Yellow, Red to Red, and Black to Green)
It turns on immediately when the switch is turned from off to either 12v or 24v even though no one is pushing the "on" tab on the foot petal.
The motor runs at the same speed (I think full speed but not sure) no matter what position the 5 speed knob is set to (Off through 5).
I'm pretty sure the boat is set up to only work on the 24v setting. I have two trolling motor batteries that are jumpered with a lead coming from the positive of battery #1 and a lead coming from the negative of Batt #2. I only used the motor in the 24v setting so I don't remember if it ever worked in the 12v setting but it does now (and maybe it always did but it sure doesn't look like its set up that way).
Anyway, hopefully this is enough for someone to troubleshoot.
Thanks for your help,
-Robert
-Robert
