Hi,
back again for some more fun, and questions I can't find answers to.
I have a Motorguide Great White 67lb thrust Model gwb67v. It's old I imagine 1998 or so, have never had a problem with it until now.
I changed out the batteries, and installed a 2 bank charger just for the the trolling motor, nothing else is wired to those two batteries. It worked fine for 2 trips out but seemed to not be as powerful as before. Then, the last time I went to use it, when I flip the toggle switch on all I get is a clicking sound in the head of the motor, no prop rotation. I looked at the wiring, it's two wires out of the head, 3 from the boat plug back to the battery, in which one of the wires is capped off. I have in series I think it's called, the black/neg to the neg on one battery the red/pos to the pos on the other battery and the jumper from the neg to pos that are left open. I am pretty sure it's wired correctly, BUT I haven't tested the amps at the batteries and then compared to the amps at the plug yet. I s this a battery/wiring problem, or something wrong with the motor? Also, I have not taken off the prop to look and see if there's fishing line or something around the shaft, but according to most it spins "freely with a magnetic feel"
I don't think it matters but the motor is mounted on a 1998 Key West Stealth flats boat. The plug is ok, I noticed lately that sometimes I had to wiggle the plug to get the motor to work, does this sound like a crappy plug?
I rewired the batteries with 6 guage but I didn't put n a breaker.
Any Ideas?
I am going to check the voltmeter in the morning, it's too late now, and the prop also.
but I'd love some feedback from anyone in the know.
Thanks!
Charles
Any Ideas?
Thanks!
Charles
