Darrenkmac
- Oct 1, 2013
- 29
My MotorGuide model 750 12/24 volt trolling motor is losing the 24 volt use during a day of fishing a tournament. I run the motor on 3 and on 24 volts for most of my fishing. I don't usually put much use on my motor and this problem has not always been there. My batteries are only 6 months old and I charge them fully. They are Exide bought at Academy and they are deep cycle 205 reserve minute batteries. Usually in the afternoon, the trolling motor stops working. I will then put the switch on 12 volts and continue fishing. Today I tested the motor while my boat was on the trailer and sitting in my shop. It would only work on 12 volts. I plugged in my onboard charger and after about 15 minutes I pressed down the switch on the pedal at 24 volts and it worked again. My question is, why would this motor only continue on 12 volts but not on 24 as the batteries got weaker. I am use to going all day on 24 volts and even in windy conditions. Any ideas ? I know the batteries wear down during the day, but this has not been a problem in the past. I was wondering about switch contacts or maybe the pot switch or relay. Could they be going bad and increasing resistance ? Just wondering if anyone else has had this problem so that I can move forward in the correct direction. Thanks, Darren
