Sgt SwingDinger
- Sep 29, 2013
- 5
i have an evinrude/johnson 1987 6 hp e6rcob motor . i was on the lake today and the motor did fine for 5-6 hours of off and on use. then all of a sudden it bogs down and dies. when i tried to crank it it would idle rough and when i give it gas it would bog and die. water is coming out of it like normal , no overheating . only thing i could do was turn the middle dial to the highest setting and pull the knob out on the left. to keep it running i had to push the knob in and out til i hit the sweet spot so it wouldnt die. when i got home i took the lid off and looked at he gas line on the left side and it had a little black piece of something in it (appeared to be plastic) . any ideas on where to start or what this may be caused by? thanks kendall
