santurinos
- Nov 2, 2011
- 8
Hello Friends,
I have a 1996 Tracker Deep V17 with a Mariner oil injected 60 HP motor.
I?ve finisher my overhauling job over the winter; I am ready to go on the water. I never used it on the water, but I could tilt and trim it when I bought it and the trim worked at my place. I used it a few times to lift or lower the motor.
But now, my motor won?t lift up. I can hear the hydraulic motor running, the switch works in both up and down direction.
But there is no movement at all on the motor and I cant lift it up manually. Of course, there is no pin to hold it.
Could it run out of oil? How could I refill it?
Thank you for your help ? santurinos.
