I brought a Mercury 1983 25hp about 6 months ago. The guy I brought it from said that it hadn't been used for a couple of years and very little before that. It worked fine from the start, with good compression on both cylinders.
After 4 months use, mostly trolling with some WOT in between it not reaching high revs at all. It started about 2 months ago, which was then an intermittant problem, but now it does it all the time. From the start it has had problems with oil build up due to sitting at idle (trolling), and after a while had the incapacity to burn it out of the cylinders.
I've overhauled the carb (plus new fuel lines and checking for any leakages), new plugs Champ L76V (gapped properly), compression now is 124 psi (top cy) and 142 psi (bottom cy), good strong blue sparks on both circuits and still has the inability to reach high revs. It just shudders (not violently) and is clearly not happy when I give it more than half throttle.
When I overhauled the carb, the float was a good 2-3mm too low, so that was adjusted as shown in my manual.
I need ideas/help, as I haven't the money to anything major nor just delivering into the workshop.
