Hi, I have a 1988 45hp Classic Fifty that I recently purchased and it will not go into reverse when the steering wheel is turned to the starboard side. If the wheel is in the center position or anywhere to the port side it works just fine. The previous owner just put in new flooring and carpet including the side panels, so I hoped he might have just put the controller and cables back in a little too tight. I moved the controller back a bit and removed a couple of hangers supporting the cables. This allowed me to experiment and move the cables around to see if that would fix problem. No luck... So with the motor off, I removed the top cowl, turned the wheel all the way starboard and pulled the shift/throttle level backwards just to the point where I could feel more than normal resistance. Then I turned the motor slowly by hand and just as it approached the center position I heard a click and the shift lever moved less than 1/2 inch back and it went into reverse. Once in reverse you can turn the wheel fully in any direction and it stays in reverse until you pull forward on lever. I repeated this again but this time before turning the motor I felt around where the cables come into motor and found what I believe is called the "cable barrel" and it was bound up and the spring that allows the cable to move from side to side was also stuck. Before I spend any money on new cables does anybody think it could be something else or maybe an adjustment that could be done? Thanks..
