Motor won’t surges then stalls
Agnewman
I have a 2019 merc 50 HP efi 4 stroke motor. It was running fine until yesterday when I accidentally ran the gas tank dry. I hooked up the secondary tank and everything went to hell thereafter. The motor would start then surge terribly and eventually stall. When I tried to restart I needed to bypass the normal system because I thought if I could rev it, it would run. No luck it would rev then sputter an die.
I suspect I picked up water from the tank and wonder if purging the fuel system might solve my problem.
Am I on the right track and if so do you have any idea of how to do this? Or should I bite the bullet and take it to a shop
