Motor will not start
LRC
I recently purchased a boat with a 1987 100hp Mariner engine. The engine has not been started in a couple of years. I just replaced the ignition switch and when I attemped to start the motor, it would turn over but not run. I tried a few more times but stoped when I found that the negative terminal on the battery was too hot to touch. I also noticed the starter seemed overly hot. What steps should I take to get this motor running properly again?
phatmanmike
Re: Motor will not start
before you try to start it, you should replace the waterpump and thermostats (if equipped) and check the compression.<br /><br />squirting some oil in the plugholes wouldnt hurt either....<br /><br />nothing worse than finding a great motor at a garage sale and taking it home only to blow it up due to lack of pre-maintance
Chris1956
captail LC - It is normal for the starter to get hot during use. It is not normal for the negative terminal or cable to get hot! Heat means resistance. I recommend you check for a dirty battery connection or rotted cable.<br /><br />PS let the starter cool off when it is hot. That way you will not have to buy a new one!
LRC
I took off the plastic cover over top of the starter and found that the starter would stay engaged and not drop back down after attempting to start it. I am going to have the starter rebuilt and hopefully that will take care of the problem.
